Der er opdatering til BaseCamp til windows.
Change History
Changes made from version 4.4.2 to 4.4.4:
◦Fixed several issues when using the Pan Tool and the <ALT> key to move route points
◦Fixed autorouting issue where straight line segments were inserted after each waypoint
◦Improved track to route behavior. Now supports preserving the shape of track sections that aren't near a road.
◦Improved handling in situations where the computer is low on memory
◦Changed displayed route times to take layovers into account
◦Fixed issue with 'higher education' map symbols showing up as airports
◦Fixed certain instances of route direction text where the text was 'turn left/right' instead of 'bear left/right'
◦Fixed issue when recalculating a route via the context menu in the data list
◦Fixed various issues sending data to memory cards
◦Changed to automatically unlock BirdsEye for a device when sending the BirdsEye to a card in that device
◦Fixed various issues with Adventure search
◦Fixed issue sending ADM files to cards for marine devices
◦Added the command line option /Disable3D to disable the 3D view in BaseCamp. This was added to prevent startup issues with misbehaving graphics drivers.
