MapInstall installs maps onto your Garmin USB GPS devices and SD card readers. Note that there is currently no support for serial or Palm devices.
MapManager copies maps and unlock codes into the right place to be accessible by MapInstall and Training Center. To migrate the maps from your Windows PC, download MapConverter onto your PC and follow the instructions.
System Requirements:
Intel based Mac running OS 10.6 or higher.
1024 MB RAM (2048 MB recommended)
USB port
Download and install MapConverter for Windows to convert your unlocked PC maps for use on your Mac.
Change History
Changes made from version 4.1.0 to 4.1.1:
Fixed issue with not cleaning up map files that failed mid-install
Fixed several crash issues
